-   -   Is a new DME the answer? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1041689-new-dme-answer.html)
GHEN 10-02-2019 05:31 PM
Hi all,
My '87 NA 944 is a great car, but at 32 years old it is a little stumbly on acceleration, idle isn't as smooth as it might be, etc.
I have worked through some things that have definitely helped (O2 sensor) J boots, etc.
My question is this:
Might I reasonably expect that putting in one of the new FTech DMEs might produce an overall smoother car, or am I throwing my money away?
I am positing that over 32 years the signals that come out of the DME might be irregular in terms of voltage, signals etc. (albeit to a small degree since the car still runs), & a brand new brain might make things better.
So what do you all think?
Reasonable or a waste of money?
Thanks in advance,
GHEN
944 Ecology 10-02-2019 05:42 PM
Waste of money. DMEs don't deteriorate performance. They either work or they don't.
Spend your money/time first fixing vacuum leaks, grounds, blueprint injectors, plug wires, spark plugs, etc.
GHEN 10-02-2019 05:46 PM
Thanks George, appreciate the advice. I've done most of your list, haven't messed with vacuum leaks yet...need to figure that out.
GHEN
944 Ecology 10-02-2019 05:49 PM
Build yourself a smoke machine, then attach it to the J boot. Any vacuum leak will leak smoke...
https://www.youtube.com/watch?v=GOhl4r0GSiE
v2rocket_aka944 10-03-2019 09:43 AM
what you do want, once leaks are fixed, is to ****-can the stock DME/AFM and get a newer ECU with a MAF or MAP setup.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
