Driver
Is a new DME the answer?
Hi all,
My '87 NA 944 is a great car, but at 32 years old it is a little stumbly on acceleration, idle isn't as smooth as it might be, etc.
I have worked through some things that have definitely helped (O2 sensor) J boots, etc.
My question is this:
Might I reasonably expect that putting in one of the new FTech DMEs might produce an overall smoother car, or am I throwing my money away?
I am positing that over 32 years the signals that come out of the DME might be irregular in terms of voltage, signals etc. (albeit to a small degree since the car still runs), & a brand new brain might make things better.
So what do you all think?
Reasonable or a waste of money?
Thanks in advance,
GHEN
'87 944
Old 10-02-2019, 04:31 PM
Waste of money. DMEs don't deteriorate performance. They either work or they don't.
Spend your money/time first fixing vacuum leaks, grounds, blueprint injectors, plug wires, spark plugs, etc.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 10-02-2019, 04:42 PM
Driver
Thanks George, appreciate the advice. I've done most of your list, haven't messed with vacuum leaks yet...need to figure that out.
GHEN
'87 944
Old 10-02-2019, 04:46 PM
Build yourself a smoke machine, then attach it to the J boot. Any vacuum leak will leak smoke...
https://www.youtube.com/watch?v=GOhl4r0GSiE
www.944ecology.com
Old 10-02-2019, 04:49 PM
what you do want, once leaks are fixed, is to ****-can the stock DME/AFM and get a newer ECU with a MAF or MAP setup.
Old 10-03-2019, 08:43 AM
