I'm working on it....
MD540iT's Avatar
got it running! Again!
WHOOOoooo…… im tired.
only for 30-40 seconds, since its loud (3.5" turbo back exhaust) neighbors complained (apts) first time I got it running. Just wanted to see if it would start.
after shut down, I turn the engine over by hand, to hopefully (incase there were any deposits) "wipe" them off by moving the valves without being sprayed on)
Old 10-15-2019, 01:41 AM
Awesome work!!!
Old 10-15-2019, 03:22 AM
Soooo!...What did you do to get it back up and running? Cleaning the varnish deposits off of it alone was the fix?
Old 10-15-2019, 04:05 AM
Iím going by the loud knocking noise ou are reporting..If on replacing the cam tower a small screw or bolt found its way in it will now be knocking around in the combustion chamber. If itís a loud knocking noise similar to bearing knock you need to pull your head immediately.
Old 10-19-2019, 06:04 AM
