gt350mike's Avatar
Speedo Needle removal
How do I remove the speedo needle? The directions say "gently" pry the needle from the speedo. My luck it will break so before I proceed, I need so moral support and guidance.
FYI - The speedo is from an 86 car w/no post at 0 mph.
Thanks!
2015 GLK (Momma's ride)
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 03-29-2003, 07:52 AM
AFJuvat's Avatar
You got the best directions that there are - you just have to pry gently.
I've had luck using a small screwdriver under the needle to work it up from side to side.
It is a good idea to mark where the speedo is pointing before you remove it - just to get everything lined up when you put it back.
Good luck!
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-29-2003, 08:56 AM
