-   -   Thermostat seating properly??? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/104294-thermostat-seating-properly.html)
gt350mike 03-29-2003 03:25 PM
I'm installing the waterpump with the new thermostat. When I put the thermostat in with the c-clip, it moves around. I checked the repair manual and it looks like it doesn't have a rubber seal between the thermostat and where it seats on the water pump. Is it ok to move around????
BTW, The new thermostat came with a rubber gasket, but it was too small to use.
HELP!
Scott R 03-29-2003 04:15 PM
Do you have part #10 shown in this diagram? I have never had one that moved around before, in fact they are water tight for the most part, and usually gush all over me when I remove it.
http://www.pelicanparts.com/944/944_...83-85/pic3.jpg
gt350mike 03-29-2003 07:36 PM
Nope! The rubber ring OD is almost the same as the ID of where the thermostat seats. I guess I'll have wait till Monday and call Ian for the gasket.
Thanks!
