LinkBack | Thread Tools | Rate Thread |
Removing an Automatic Transmission
1987 Black Porsche 944 N/A Last edited by jtehfreaks; 10-18-2019 at 06:09 PM.. |
Looks correct 2 bolts going through perpendicular to transmission. As your going to this trouble replace the mount with an uprated no rubber mount.
Be nice to have a 968 4spd autobox and torque tube I’m sure there will be a few modifications with mounting and positioning though, something I’m thinking about for the future. |
I initially thought about tossing in a tiptronic, and after running the idea by a few people, the gear ratios would make the 944 slower than it already is. Then there's the electronics to worry about too, so I'm keeping it with a 3-speed. What's the benefit of swapping to a solid mount? Won't that just transmit more noise and vibration into the cabin?
1987 Black Porsche 944 N/A |
I have a 87 auto I'll sell you cheep if interested, it's still in the engineless car if you want that also. I had a manual clutch disk in it that replaced the flex damper. The engine block had a crack so I parked it and been using it for a parts car.
I'm in northern NV, probably not worth shipping it though. |
More progress on the removal!
Step 8: Remove the two 8mm hex headed bolts on the right side of the transmission; it helps a lot to get the fuel filter mount off of the crossmember and moved aside, while also undoing the crossmember bolts at this point. With the crossmember loose, you can lower the transmission a bit and rotate the crossmember around to get better access to these bolts. The bolt on the right didn't require any extensions, just the bit and a breaker bar, but I had to daisy chain a couple extensions to get to the bolts on the left so I could break the torque on it. You can also see how lucky I got removing the right bolt; it was rounded out really badly. I had to take a punch and drive the bit in; luckily, it had plenty enough bite and took care of this bad boy. ![]() ![]() ![]() Step 9: Remove the four bell housing bolts. Three of them are 10mm hex head bolts, while the fourth requires a 17mm socket. One of the hex bolts has a 19mm nut behind it as well, so you can counter one to break the torque on the other. To be honest, none of these bolts put up much of a fight, and I feel like they may have been under torqued. ![]() ![]() Step 10: Separate the torque tube and the transmission. There's a half-circle on the left side of the tranny that you can get a pry-bar in to leverage against the two pieces; it'll work the tranny partly out, then just use a big screw driver and wedge the rest of the transmission away from the torque tube. As you lower the transmission, keep an eye on the torque converter so it doesn't fall out, mine stayed in place, but it feels like it can easily slip off if you aren't careful. Don't forget to unplug the electrical connector at the top of the transmission before you lower it too much and start rolling it away! ![]()
1987 Black Porsche 944 N/A Last edited by jtehfreaks; 10-20-2019 at 09:16 PM.. Reason: Updated some steps. |
Thread Tools | |
Rate This Thread | |
