924 fuel pump
I am working on a 1977 924 that had set for 25 years, I have replaced fuel pump,lines & injectors.Engine is hard starting. My question, is the fuel pump suppose to run when key is in run position,or only when cranking .thanks
Old 10-21-2019, 10:29 AM
Here's a good website for the early 924 owner.
Porsche 924 Garage & Register home
Old 10-21-2019, 10:36 AM
I can hear mine when I turn the key, just before it cranks. I'm also using a Focus9 Fuel DME...
Old 10-21-2019, 11:56 AM
GuyS's Avatar
No, there is a sensor on the air meter plate that senses movement. Pump only runs when cranking. Not before. I often wondered if a 928 CIS fuel relay would be a good upgrade. It runs the pump for a few seconds every time its energized.
Old 10-22-2019, 10:50 AM
ideola's Avatar
Early 924 pump should run for a couple of seconds to prime the CIS system. The early relays are near impossible to find. Go to 924board.org and do some searching on early 924 relay, as I can't recall from memory the part numbers and such.
If the car is hard starting, it's more likely that the warmup regulator needs to be rebuilt / replaced, AND/OR that the thermo-time valve + cold start valve are not functioning correctly.
If you search in the How-To section of 924board, I have a complete writeup on using a Hoffman CIS pressure tester that explains the diagnostic procedure directly distilled from the Bosch CIS book (something I strongly recommend that you add to your library).
The Focus9 DME relay referenced above is for a 1987-88 924S that has the 944 engine and DME. The early cars do not have this setup, so that will not work for the '77 mentioned by the OP.
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 10-31-2019, 07:43 AM
Lots of good stuff on CIS in the 911 section too. As Ideola states, spending $90 on a good quality (not HF) CIS-specific fuel pressure tester is THE best thing you can do. John
Old 10-31-2019, 12:07 PM
