theer's Avatar
Horn works/doesn't work
I need help figuring out the horn on my 85.1.
The horn works, but only when the steering wheel is turned left or right at least a quarter turn. I'm thinking the ground path is interrupted ... somewhere, somehow... but am at a loss on where to start looking.
Any ideas?
Thanks,
Tom
Old 10-21-2019, 10:25 AM
Thumbs up
sliding rotary-style contact between the steering wheel and hub.
Old 10-21-2019, 02:29 PM
Check for loose u-joints in the steering shaft. The ground signal uses the steering shaft. In a pinch, you can use wire to shunt the signal around the u-joints.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 10-21-2019, 04:32 PM
Just thinking out loud
mattdavis11's Avatar
Probably not your problem, but mine was at the cross member. Ground was no good.
91 FJ80
84 Ram Charger (now gone)
Old 10-22-2019, 08:21 PM
theer's Avatar
Thanks all for the suggestions. I'll check it out this weekend.
Old 10-23-2019, 10:21 AM
