Gas Leak
When I took my 944 out of winter hibernation last spring, the first few times I drove it, I'd come out the next morning and the garage would absolutely reek of gas. I checked underneath, but found no visable leaks. As the weather got warmer, the problem went away. Well, last September, when I parked it for the winter, the leaking started again. This time I caught it actually dripping onto the garage floor. Above the fuel filter, as I feel along the tank ridge, is a layer of foam or rubber insulation (not sure which). When I squeeze this with my fingers, fresh gas leaks onto my hand. Is this a likely place for a tank leak? The lines look ok, haven't had it on a hoist yet though. Any advice welcome.
Old 04-25-2000, 03:17 PM
Send a message via ICQ to Ptech
There are several lines on top of the tank , and a vapor separator . you need to take out the rear carpet
( under the hatch ) and the sending unit cap , and see if the sending unit is leaking .
The only other thing that leaks is the fuel pump lines or the seals at the banjo fittings.
ptech
Old 04-28-2000, 04:04 AM
