-   -   Automatic Transmission coolant hose seals (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1044071-automatic-transmission-coolant-hose-seals.html)
tx944fan 11-01-2019 12:23 PM
87 944 automatic transmission question. The pressure side auto transmission coolant line is attached with a ‘banjo’ bolt (7) and sealing rings to the union on the case. The parts catalog attached shows 2 seals (6) on the Union side of the fitting and one on the bolt side. I don’t think there were 2 there when I took my transmission out and 2 seems like an invitation for leaks. Anyone know if there are really supposed to be 2 seals there?
http://forums.pelicanparts.com/uploa...1572635773.jpg
djnolan 11-01-2019 03:31 PM
maybe one seal on each side of the banjo fitting?
onZedge 11-01-2019 06:34 PM
Banjo fittings only require one seal per side.
jtehfreaks 11-09-2019 08:06 AM
When I pulled my transmission, there were indeed two washers on that side of the banjo fitting, making three total. I thought it was weird, but there was no evidence of leaking from that fitting, and I suspect the second washer may be acting as a spacer for fitting purposes.
tx944fan 11-09-2019 04:53 PM
Well, I put all three in and no leaks. The two inside ones seemed like they were both needed to fill the gap since the sealing surface was recessed.
Thanks for the replies.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
