tx944fan's Avatar
Automatic Transmission coolant hose seals
87 944 automatic transmission question. The pressure side auto transmission coolant line is attached with a ‘banjo’ bolt (7) and sealing rings to the union on the case. The parts catalog attached shows 2 seals (6) on the Union side of the fitting and one on the bolt side. I don’t think there were 2 there when I took my transmission out and 2 seems like an invitation for leaks. Anyone know if there are really supposed to be 2 seals there?
Old 11-01-2019, 12:23 PM
maybe one seal on each side of the banjo fitting?
Old 11-01-2019, 03:31 PM
Politically Incorrect
onZedge's Avatar
Banjo fittings only require one seal per side.
Edek
'87 924S
'91 535i
Old 11-01-2019, 06:34 PM
Send a message via Skype™ to jtehfreaks
When I pulled my transmission, there were indeed two washers on that side of the banjo fitting, making three total. I thought it was weird, but there was no evidence of leaking from that fitting, and I suspect the second washer may be acting as a spacer for fitting purposes.
1987 Black Porsche 944 N/A
Old 11-09-2019, 08:06 AM
tx944fan's Avatar
Well, I put all three in and no leaks. The two inside ones seemed like they were both needed to fill the gap since the sealing surface was recessed.
Thanks for the replies.
Old 11-09-2019, 04:53 PM
Tags
automatic transmission , hose seal
