86 944 Motor mounts
Does anyone know of a published procedure for replacing motor mounts?
Thanks!
Ron
Old 04-29-2000, 10:48 PM
lm6y's Avatar
Check out the Hayne's manual. It gives some good info on some things, and none at all on others. All in all, it's one to own if you own a 944.
Old 04-30-2000, 07:18 AM
Send a message via Yahoo to Cebu
Go to Http://geocities.com/MotorCity/Garage/3192
Click on "Repair Procedures"....
I did mine by just unbolting the mounts, disconnecting and removing the Air intake hardware up top and jacking the engine up enough too remove and replace the mounts. (Using great care not to overstress the exhaust/manifold system) and make sure battery is disconnected so that starter does not ground to underbody.
Cebu
Old 04-30-2000, 08:37 AM
Thanks much for the reply.....
Old 05-01-2000, 06:40 PM
You will need a couple of jacks. You have to drop down the cross member that holds the steering rack and motor mounts, while holding the engine up at the same time. Do one side at a time.
Its a pain. becareful!
Old 05-02-2000, 04:33 AM
