-   -   oxygen sensor (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/10442-oxygen-sensor.html)
NvrFstNF 04-20-2000 12:14 PM
oxygen sensor
I'm the new owner of someone else's problem. The oxygen sensor wire has been cut and I don't know were it is suppose to attach to. Does the wire connect to the orange thing mounted on the fire wall and near the center? If not, then where?
1983 944
[This message has been edited by NvrFstNF (edited 04-20-2000).]
1.2gees 04-24-2000 07:04 AM
Yes, that's where it goes, I'd try to find out why it's been cut, maybe bad sensor? (They're pretty expensive, ~120$)
divezic 04-24-2000 11:01 PM
Depends on what kind of O2 sensor you have, you'll pay between $30 and $120. My 84 944 has a single wire and I paid $30 for the O2 sensor. The 3-wire sensors (the ones with the built-in heating element) are more expensive and are found on later models.
When you replace the wire, make sure you use a high quality replacement wire and connector. A cheap, high resistance wire will screw up the signal to the computer.
Doug M 04-26-2000 09:47 AM
Does anybody know how to test the O2 sensor?
I think mine is bad.
NvrFstNF 05-01-2000 10:37 AM
Here is an update on my problem. The 02 wire was cut/broke in four places. One at the sensor itself, the second at the connector, and the third and fourth breaks were at both ends of the orange connector. I ended up by-passing the orange connector thing and hooking up the O2 sensor directly to the green wire. The green wire on the wiring harness side of the orange thing contains two wires in it. I connected the sensor to the middle wire and left the other wire disconnected. I don't know if the sensor is working correctly now or not. There is a couple of good pictures in the Haynes manual under the subject of intake manifold removal or something. It shows a two terminal connector connected to the O2 sensor. I'm thinking this is for heated 02 sensors. The car seems to be running pretty good now. Mostly because I plugged up a huge vacuum leak; it made a huge difference in the way the car idles. It's real smooth now. The vacuum leak was located between the intake manifold and the head. Cylinders 3 and 4 were both leaking.
