-   -   Engine Out Equals Floppy Tranny? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1044452-engine-out-equals-floppy-tranny.html)
OK-944 11-06-2019 04:39 AM
Dropped out the engine from my ’87NA awhile ago…and yesterday, while underneath the car’s back end, I noticed that the rear axles and trans looked askew. I then noticed that I could very easily rock the trans back and forth (more like rotate the trans around the torque tube axis) by hand. Is this normal? Makes sense that some flexibility is needed in this area…but this much?
9FF 11-06-2019 05:57 AM
The whole powertrain (engine, torque tube & trans) is supported by only three pieces of rubber and you’ve removed two of them. Don’t worry about it.
OK-944 11-06-2019 07:33 AM
Just looked a bit harder and figured that out...but thanks! At any rate, the tranny will hang for awhile so I went ahead and blocked it from the ground for some support.
v2rocket_aka944 11-06-2019 10:06 AM
best thread title ever.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
