What is YOUR broken 924S timing belt experience?
Hello,
I know it has to go in for a true diagnosis and damage assessment, but what has your experience been with a broken timing and balance belt? A few bent valves? Many? Worse? I bought a 924S with a broken belt and just trying to gauge how bad to expect.
No real info on what was going on when it broke.
Thank you for any experience info.
Old 11-09-2019, 04:27 PM
I had a 944 turbo break a belt on the interstate doing about 70 mph. I was very lucky in that I only bent 3 valves and did absolutely no other damage. Most are not so lucky.
Old 11-09-2019, 06:14 PM
9FF 9FF is offline
9FF's Avatar
A few bent valves and a couple of piston top dings. So only valves, guides, stem seals and a light skim on the head if you’re lucky. It’s very rare that anything breaks loose and damages pistons and bores but I’ve heard it happens.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 11-09-2019, 06:19 PM
Thank you!
Old 11-10-2019, 05:23 PM
Thank you!
Old 11-10-2019, 05:24 PM
GuyS's Avatar
One broke on me at idle. One bent exhaust valve. Not sure how that happened but only one with no other damage
Old 11-11-2019, 11:26 AM
My engine just shut down so I had turned it off and placed it in neutral as fast as I could and I had no piston damage just a few bent valves.
Old 11-11-2019, 03:17 PM
