Newb
mone_biz's Avatar
968 19mm m030 adj. sway bar installed on 924S hitting chassis
any help and or suggestions would be great. see photos of contact point, it is making noises on undulating bumps. car has stock suspension, except for some koni yellow shocks.
Old 11-11-2019, 12:48 PM
curtisr
curtisr's Avatar
From Paragon Products comes this note:
The Original Porsche 968 M030 19mm adjustable rear sway bar will finish out your 924, 944 or 968 suspension. The adjustable rear bar will allow you to fine tune the handling of your car so you're quicker on the power and quicker around the track. If your car understeers, just move the sway bar drop to the next stiffer position. Cars without a factory rear bar will require adapter SB6900 or SB6910 and a pair of factory drop links 477.511.051A or KLA Spherical Drop Links. Seeing an installed sway bar this is probably not an issue. The installation instructions, however, should be of greater help.
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 11-12-2019, 05:35 AM
Newb
mone_biz's Avatar
understood, i have already installed the sway bar, with new factory bushings, and the car already had a factory 14mm sway bar, so it was an easy bolt on. trying to figure out why the bar is hitting the support where the rear trailing arm attaches to the torsion tube. And is this a common issue?
Old 11-12-2019, 08:19 AM
9FF 9FF is offline
9FF's Avatar
Are you using the correct sized stock rubber bushings?
Are you using stock or adjustable drop links?
If adjustable did you adjust to dial-out any pre-load?
Did you tighten all the nuts and bolts with the wheels on the ground?
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 11-13-2019, 03:46 AM
Newb
mone_biz's Avatar
new oem 19mm bushings, stock drop links, yes
Old 11-13-2019, 12:39 PM
9FF 9FF is offline
9FF's Avatar
You didn’t answer if you tightened everything with the wheels on the ground. If you did it all on jacks then you’ll have introduced some pre-load that may be causing issues. Don’t forget rubber doesn’t slide like poly or Delrin, it twists in torsion and it can only twist so much.
Sort of grasping at straws here in the absence of anything obvious.
Mike A
Old 11-13-2019, 01:55 PM
curtisr
curtisr's Avatar
The installation instructions addresses this.
Old 11-14-2019, 04:18 AM
