-   -   stuck heater side control (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/10454-stuck-heater-side-control.html)
85944na 04-27-2000 08:30 PM
the lower slide control for my climate control on my 85 944na (early) is stuck it will go back and forth between half way and full heat but my heater wont go off, has this happened to anyone else, and does anyone know what it may be?
944Driver 04-27-2000 09:17 PM
My 83' 944 has the same problem. I had a broken slide clip. That's replaced, but I still can't turn off my heat. I've ordered a new heater control valve. I intend to replace that in the next couple of weeks or so. I'll post how it turns out.
85944na 04-28-2000 06:06 PM
thanks, my heater valve is aso in the process of being replaced hope it works!!!...hope i dont need a core
thamlin000 04-29-2000 03:09 PM
My 83 944 is the same way. I just fiddle with it for a while to turn on and off the heat. Unlike most stuff on the car, the heater control knobs on early 944s seem to be of low quality engineering. I don't know how to fix it, but I can reassure you that you aren't the only one with that problem.
Cebu 04-30-2000 08:44 AM
Check the fuse(main fuse box on 86 944) for the heater..when it is blown you have continous, uncontrolled heat.
Cebu
85944na 05-03-2000 02:14 PM
MIne is fixed!!!!!!!!!!!!!, teh cable that the slide control moves got all twisted in mine, a friend of mine put in a new cable and its all good now! hope this works for teh rest of you guys =)
944Driver 05-13-2000 10:55 AM
Finally got around to replacing my heater valve. What a job! Five hours later, I seem to finally have cold air. The valve was definately the culprit with my heat problem.
1.2gees 05-13-2000 01:07 PM
My defroster doesn't work, the slider never allows air to be blown through the upper dash vents, could this be my problem as well? A clip on the slider at the center console? any ideas tips?
Thanks.
85944na 05-15-2000 04:00 PM
is your slider stuck or very loose?..if so it could be a cable
1.2gees 05-15-2000 06:47 PM
Neither, feels just like the heat slider, or the other vent one, maybe a bit more loose, but not by much, so what do you suspect? Cable, a clip?, the fork that holds the cable, right behind the slider it self? I don't have any idea about the inner workings of this system, never had it apart. Is it hard? time consuming? I used to work as a mechanic, and I do believe I have a general understanding of things like this, but I'd appericiate more clues/tips/ideas.
greg c 05-16-2000 12:55 PM
I had the same problem, a small piece of plastic with the retaining clip for the cable broke off. I fixed it by tie rapping it to one of the other cables so the cable would move though the housing.
1.2gees 05-16-2000 04:39 PM
I'll try to look into that, and will post results when I get around to it, thanks for the tips.
Ahmet
