Cold Start Issue???
Been having a cold start issue...at first I thought it was the fuel pump...then I tried Clark Garage's DME Relay Jumper fix...it worked and started the car...I immediately went and brought a new DME Relay from Amazon got it today popped it in...it would not start the car...put modified relay back in the car started...What gives??? is the DME computer not sending a signal to turn on the pump or could the new relay be just bad?
Old 11-16-2019, 06:50 PM
Anybody? Do you think the Dme is not sending the signal for the fuel pump to fire and when I jump it supplies power straight to the fuel pump so the car fires?
Old 11-17-2019, 11:59 AM
Well it was the factory alarm...made a jumper per Clark's Garage and viola! turn on first key again....just wanted to let everybody know if this happens to them what they should be looking for check here first
Old 11-18-2019, 05:41 AM
