914ltd
Engine kicks back on starter
I have a low miles 87 base 944. When starting, the engine occasionally fires before TDC like a distributor turned too far advanced. I checked the timing marks on flywheel and camshaft/distributor pulley. They are OK. Thanks in advance!
Brad Mayeur (914 guy)
Old 11-21-2019, 02:53 PM
If you have the small diameter, gear reduction starter, it generates enough stray magnetism into fooling the flywheel TDC sensor into firing on the compression stroke.
Porsche introduced a new sensor bracket, and a sleeve to combat this problem.
The other fix is to replace the starter with one of the older design.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 11-21-2019, 03:09 PM
9FF 9FF is offline
9FF's Avatar
+1 what 944 Ecology said, it’s because they notched the bellhousing on the 1987 model <details>
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 11-21-2019, 07:45 PM
