-   -   Underhood courtesy light (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1046227-underhood-courtesy-light.html)
GHEN 11-28-2019 05:54 AM
Hello All, Happy Thanksgiving.
My under hood courtesy light isn't working. I bought a replacement bulb but that doesn't seem to fix the problem. I am going to figure out some way to sand out some oxidation within the bulb socket to see if that is the problem but if not does anyone have any ideas?
The switch that turns it on/off based on hood position moves freely and the wires don't seem to be compromised at all.
I have a voltmeter/multimeter but frankly I don't know how to use it to test the bulb socket.
Any thoughts or a quick "how to" with the voltmeter?
Thanks in advance!
GHEN
curtisr 11-28-2019 06:01 AM
Try putting the right blinker on when checking it.
GHEN 11-28-2019 06:04 AM
Originally Posted by curtisr (Post 10672464)
Do you have the right blinker on when checking it?
I don't...should I?
GHEN
pfarah 11-28-2019 06:09 AM
Actually Ghen, it's very easy.
1. Simply remove the bulb
2. Set your Volt/Ohm meter to DC volts (20vdc or thereabouts)
3. Turn your car's light switch on (parking works)
4. Place the red meter lead on the center contact in the light socket (Positive/Hot)
5. Place the black lead on the socket's side (Negative/Ground)
6. Read the results - You should see a value of 11.5 - 13.0vdc; any reading will prove that there is continuity.
Note: Try not to touch the leads together; you'll end up blowing a fuse/relay. Good luck!
curtisr 11-28-2019 06:12 AM
Originally Posted by GHEN (Post 10672467)
I don't...should I?
GHEN
I believe that to be the case.
9FF 11-28-2019 06:19 AM
There’s some good info in this thread: http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/863104-under-hood-light-not-working.html
GHEN 11-28-2019 06:24 AM
Originally Posted by 9FF (Post 10672486)
Thanks Mike!
GHEN
GHEN 11-28-2019 06:31 AM
Thanks, I'm going to try this now!
GHEN
kdjones2000 11-28-2019 06:52 AM
The light only works when the turn signal is on (I thought it was "left", but not sure).
Give Curtisr some props for that one :)
GHEN 11-28-2019 07:09 AM
Props!
GHEN
GHEN 11-28-2019 07:10 AM
Patrick,
PM sent.
Thanks,
GHEN
pfarah 11-28-2019 07:34 PM
Responded...
curtisr 11-29-2019 06:00 AM
http://forums.pelicanparts.com/support/smileys/yawn.gif
It should also work when the parking lights are on. Batteries are out of the cars at the moment so I'm relying on my unreliable memory. Sorry, I hate guessing...
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
