hmd hmd is offline
944S2 pics
few pics of konis coilovers, custom made harness bar and dyno graph of before and after Powerchip (minimal difference to the power at WOT).
76 Carrera 3.0 (Group Sc)
Old 04-01-2003, 02:22 AM
PorscheG96's Avatar
Send a message via AIM to PorscheG96
Those are the same rear shocks/helper springs I plan to install on my car soon [968 m030]. Did you have to re-index the torsion bars or simply lower the the rear with the eccentric to bring down the ride height? How much of a gap do you have between the rear fender and tire now?
What dimensions and rate are your front springs? I have some 2.5"x10" 200# springs that I'm hoping will fit with a threaded spring collar. Looks good!
Old 04-01-2003, 08:41 AM
hmd hmd is offline
I don't know I got a Porsche race car specialist to do it for me
There is not much of gap between the rear fender and tire, especially when I put my 17" 255 wheels+tire on. Will get some pic of the 17" soon.
Old 04-01-2003, 12:52 PM
Scott R's Avatar
I also have a rear coil suspension, I removed the torsion bars as they were no longer needed.
Your ride height should be controlled now at the threaded collars on the new shock assy.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-01-2003, 01:27 PM
PorscheG96's Avatar
The 968 m030 rear shocks don't have a threaded housing. There's no way to adjust ride height except with the factory eccentrics.
The reason I'm wondering if the torsion bars will need indexing is that, with 125# of extra spring force in the rear and stiffer shocks, the rear end won't sit as low as it did before. I'm hoping that anything gained in ride height from the extra firmness can be taken out with the eccentrics and not a massive torsion bar overhaul.
The fronts will have threaded spring collars, so getting the correct ride height will be cake.
Old 04-01-2003, 01:55 PM
hmd so what was the verdict on the powerchip? Do red and blue sginify torque and hp? Is this chart the after chart?
'94 968 Coupe, 6 Sp, Polar Silver on Blue, w/ 993 Seats, 17" Cup 2's, Premium Sound, Matching Spoiler, Window Express, Blaupunkt Honolulu.
http://hobbystage.net/porsche/polar/
Old 04-03-2003, 07:09 PM
hmd hmd is offline
The red is the powerchip the blue is the factory chip, the top lines are powers the bottom are torques.
The verdict is minimal gain the only reason I am keeping the powerchip is for the 500rpm extended rev limit. It comes in real handy on very tight track.
Old 04-03-2003, 08:22 PM
