Low Fuel Lamp not working
I decided to test whether my low fuel lamp would come on. This was a stupid thing to do without a can of gas in the car, but I was able to idle down a hill and just-about coast into a gas station before running out of fuel.
Any usual suspects I should consider? The fuel gauge works fine - just no lamp on the gauge of my 1984. All the other lamps on the gauge work perfectly, so I'm surprised this one is not coming ON when it should.
Thanks for the help.
Old 01-18-2020, 07:09 AM
Bulb or bad connection at sender.
Sent from my SM-G955U1 using Tapatalk
Old 01-18-2020, 08:09 AM
or bad sender.
Good luck, George Beuselinck
Old 01-18-2020, 09:05 AM
There is a wire in the fuel sending unit that likes to break off. This is most likely your problem
Old 01-18-2020, 09:47 AM
here is a piture.
The broken wire is the low fuel light wire. You need to solder it back on
Old 01-18-2020, 09:51 AM
