gearhead290's Avatar
Send a message via AIM to gearhead290
Wink My butt...
The butt of my car sags. I think it' sjust a suspension thing...can I adjust it so that it doesn't sag?
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 04-04-2003, 01:43 PM
AFJuvat's Avatar
Do you have Koni's
The stock suspension setup doesn't lend it self to too much adjustment
Most likely, your shocks are just worn and need replacing.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-04-2003, 01:44 PM
I don't think I have koni's. Wow, more suspension work to be done. we'll just add my car onto the list (my friends and I are doing 3 cars tonight, 2 Mazda MX-6s and a Ford Probe. It's just a shame only one of the MX-6's actually got good stuff...the other two kids got junk.)
Old 04-04-2003, 02:56 PM
speedy007's Avatar
duh!!!!!!
shocks may assist in height but the situation is from weak or out of adjustment torsion bars. the shocks only control the bounce, height is controlled by the springs and leaning is the swaybars.
88 944 bastard
Old 04-04-2003, 03:35 PM
speedy007's Avatar
and if you have the proper tools there is a adjustment that can be done pretty easily under the rear.
88 944 bastard
Old 04-04-2003, 03:36 PM
Scott R's Avatar
This is true, you probably just need to adjust the rear arm eccentric bolt.
Somewhere there is an article on this, with pictures.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-04-2003, 04:01 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Originally posted by speedy007
duh!!!!!!
....uhmmm how the torsion got out of adjustment would be interesting to know.... and also as far as i know there are no springs on the 944... i am assuming you meant the torsion bar? My old mercury bobcat had some beautifull leaf springs ............
What AF said is true...if nothing else has been changed.... the rear shocks will cause the rear end to sag somewhat... start at the easiest.
1. shocks..... should be easy to check...
2. torsion bar...you better know what you are doing.
3. eccentric bolt.... only minor adjustments can be made..
but if you wish to adjust ....
http://members.rennlist.com/944sandmore/torsbar2.htm
http://64.226.197.185/Paragon/Tech/944_rrha.htm
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 04-04-2003, 04:48 PM
speedy007's Avatar
yes, you assumed correctly. althou,
i think;
1 shocks
2 eccentric
3 reindexing bars
youd be surprissed how much adjustment there is from 1 end/stop to the other.
88 944 bastard
Old 04-04-2003, 08:21 PM
Paulbav's Avatar
Try this it helped me sort out my rear ride hight V good http://boerger.golden-tech.com
Good luck Paul
1990 944S2
(Gone to a new home)
1989 911 3.2 Carrera sport
slate grey
Old 04-05-2003, 07:00 AM
I always knew 911's had a big rearend. And I love 944's for thier hourglass shape. But Geeze, if my 944 started to go saggy I'd throw her away and take the big-bottomed babe!
P.S. I'm drunk, hope that explains a few things
Old 04-05-2003, 10:28 PM
