Can't get into gear, Please HELP
Something wierd happened. I can't get my 86'951 into gear. It will pop into gear fine when the engine is off, but not when on. It happened once before, about a month or so earlier. I didn't think anything about it. Otherwise she felt fine, no odd behavior until now. I drive kinda hard. I hope I didn't break anything. She's got 98K on her with 30K on the clutch. My manual is in storage until I dig them out.
Any ideas? Thanks. |
Check out my post: Major clutch problem, please help. Tell me if any of this is like your problem.
'83 944 Tim |
Could be a leaking clutch slave cylinder
How do you mean? Or how do I check it out? There's no leaking outside the car...
I once had a defective clutch slave cylinder, there was no leaking noticable from outside the car, but every time I got in the car after it sat for a while I would have to pump the clutch a few times in order to get it to work, and get the car into gear.
Unfortunatley I didn't do the work myself so I can't really advise you on what to look for, I only know the symptoms. Perhaps 1.2Gees can advise you on where to look. |
Hmm
I would think tweeks.com *************** **********.com or if you want to go used, Pelican parts, or foreignintrigue.com should be amond the better suppliers, and Pelican parts is a good one too, with excellent instructions (and tech articles). Good luck, Ahmet ------------------ It's all the driver... |
| All times are GMT -8. The time now is 02:24 AM. |
