Driver
Pretty sure I need new CV joints - PICS
Good Morning All,
Started off earlier this morning getting the axles out to clean and re-pack...well maybe not.
Looking Good, all up on jack stands and secure
Got the right axle out without much problem, even with the Stage 8 locking fasteners it wasn't too much trouble.
I took the axle to the local spray it yourself car wash to get the majority of the grease out of there. This was amazingly successful! BTW, does anyone know what that yellow paint might be from?
After getting the outboard side apart, I found the following. I think I need new CV joints, probably going to drop the extra $ and just buy 2 axles with everything already assembled. I welcome your thoughts.
'87 944
Old 02-16-2020, 08:32 AM
AirBorne!
IMHO just buy new axles. You'll get new axles and four new CV joints, no mess, just plug and play. Our host sells them:
https://www.pelicanparts.com/More_Info/94433203801M60.htm?pn=944-332-038-01-M60&bt=Y&fs=0&SVSVSI=944M
And while you are at it replace the axle to hub nuts:
https://www.pelicanparts.com/More_Info/90091009302M100.htm?pn=900-910-093-02-M100&bt=Y&fs=0&SVSVSI=944M
And since you have the car and axles out check your brake rotors and pads, rear sway bar drop links and I'm sure I'm forgetting many more maintenance items.
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 02-16-2020, 09:02 AM
Coeur d'Alene, Idaho
It's too late now, but you could have just repacked them and swapped the axles so the parts are being torqued against the fresh faces on the other side of the joint faces. A lot of the newer CV joints on the market are cheaper steel than the original Porsche parts were back in the day.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old Yesterday, 08:22 PM
