85944na's Avatar
Send a message via ICQ to 85944na Send a message via AIM to 85944na
Cooling fans
I just went and got my car again and I have it on campus, damn I can't believe how many people just stare at it I probably drove it 150 miles today. Ok but here's my question, my cooling fans aren't coming on when they are supposed to, sometimes they will come on, but not always, so to keep my car cool I've been running the ac a bit and then the fans kick in and cool the car down, what do you guys think is wrong?
PORSCHE: NOTHING EVEN COMES CLOSE
Early 85 G-red 944na, S2 transmission, Ice Shark grounds, Cibie E-Code lights, turbo rear valance, 924S gauges, Turbo S full power seats, "Porsche" door handles, Enkei Wheels.
95 Infiniti G20 dark red metallic-for sale soon
87 BMW 325ic Bronzit, stock(for now)
Old 04-10-2003, 09:45 PM
85944na's Avatar
sorry, posted this twice...
Old 04-10-2003, 09:54 PM
PorscheG96's Avatar
Send a message via AIM to PorscheG96
When was your thermostat last replaced? Assuming that it functions properly, here's what I'd suggest.
Unplug the temperature switch on your radiator. Since you have an early car the plug should have only 2 leads. Use a small wire to connect the leads [grounding the fans] and see if they run properly. If so then it's possible your temp switch is bad. If the fans don't operate when you connect the leads then your fan relay could be having issues.
Old 04-10-2003, 11:10 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Also, before you start trouble shooting, check your fuses. That was a quick fix for me recently
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 04-11-2003, 02:51 PM
