ilikemy944's Avatar
Send a message via AIM to ilikemy944
Pffft.... High Idle :(
Well, after replacing my TPS, the car is so fun to drive again yay!
But...
Sometimes it tries to idle between 1100 and 1500 rpm...
Usually drops to about 1500, holds for a sec around there, then will drop to about 1100. If I leave it to idle at 1100, it will sometimes drop, after about 15 seconds to around 1000.
It only does this in a strange pattern, after driving around for a while it will start doing it, and do it for a while, don't know if its a warm-related issue, but it very well could be.
Any ideas?
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 04-05-2003, 04:44 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
This may be due to a vacuum leak somewhere. Check your vacuum lines for cracks.
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 04-06-2003, 08:38 AM
coupe's Avatar
Excuse my ignorance, but what is a TPS?
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 04-06-2003, 10:26 AM
ilikemy944's Avatar
I'll go check the lines, I did replace the intake boot though...
TPS - throttle position sensor, or I guess I've heard throttle switch more around the p-cars....
Brad Tompkins
Old 04-06-2003, 12:56 PM
I would check the boot for leaks also and any other rubber part that can crack
3-924's (Sold)
1967-912 (Traded)
Old 04-06-2003, 04:48 PM
