Patrick
pfarah's Avatar
And Now The Brakes...
I guess it's time to rebuild the rear calipers and I might as well take a peak at the rear parking brakes since it's one of the last systems not addressed since my ownership. Here's what I found:
Not too hatefully but it looks like the outer axle seals allowed some grease to escape so I did spend a fair amount of time cleaning...
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 02-22-2020, 01:52 PM
Patrick
pfarah's Avatar
BTW: Removing the 36mm castle nut was a piece of cake, just a crow bar and my old 1/2" electric impact gun.
Re-installing the nut to 350 ft/lbs... Well, I haven't got to that yet.
Old 02-22-2020, 01:55 PM
Patrick
pfarah's Avatar
I figure I'll replace all the hardware/springs while it's all apart.
Old 02-22-2020, 01:58 PM
Patrick
pfarah's Avatar
The one issue I've run across is that the outer axle sleeve (shim?) is NLA; the driver's side is a little buggered up so I'll attempt to clean it up with some 1000/1500 emory paper. Also, I noticed there's a pretty thin O-ring on the hub (never would have found it without reading the manual).
Old 02-22-2020, 02:03 PM
Patrick, that's pretty crusty in there! Those springs and linkage parts might clean up OK? John
Old 02-22-2020, 06:35 PM
Patrick
pfarah's Avatar
Hey John,
The springs appear to be in working order but I'm going to replace most everything in there anyway. The bow is in good shape but new pins/pin locks will also be ordered. It looks like these assemblies were never touched, however; I did replace the pads about 4 years ago as there's still plenty of meat on them.
Old 02-22-2020, 09:44 PM
911tracker85's Avatar
here is what I found lurking behind that piston and destroyed dust cover in the last two brake rebuilds of older 944s. both sets cleaned up nicely but took a bit of 'elbow grease'.....
good luck.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 02-23-2020, 06:30 AM
Bob, that looks like something from a space/horror movie. John
Old 02-23-2020, 12:38 PM
Patrick
pfarah's Avatar
Funky indeed.
Old 02-23-2020, 04:27 PM
yea it was gross....
after having to rebuild the front calipers for a guy because they had rusted together and no longer sliding. found this in the front calipers.
when I suggested I rebuild the rear calipers he asked if it was necessary. but then proceeds to tell me about the maritini racing stripes he planned to have painted on the car. he relented and I rebuilt them and yes they needed it too.
in both cases I suspect I am the first to pull those calipers apart.
Bob Cox
Old 02-24-2020, 04:57 AM
Yup...can't see those stripes from the drivers seat - but I sure as heck can feel that tree I just plowed into because my brakes failed! Jeeesh! Mechanicals First - Always!
Old 02-24-2020, 06:20 AM
Patrick
pfarah's Avatar
Might as well keep going while I'm in there, right?
The bearings look and feel good but let's just replace them anyway. Who knows if/when that's been done.
Old 02-24-2020, 04:13 PM
Patrick
pfarah's Avatar
Been waiting on parts which came over the weekend. Also, I had some parts cleaned (glass bead/walnut shell blasted)and painted if needed.
Old 03-01-2020, 01:08 PM
Patrick
pfarah's Avatar
Assembled parking brake assemblies this afternoon:
Old 03-01-2020, 01:10 PM
Patrick
pfarah's Avatar
I do have a question though...
Does anyone know the rear axle seal thickness? The old inner seals measured at 8.00mm while the replacements are 9.80mm. The outer seals also measure at 9.80mm. According to the shop manual, both inner and outer seals are the same part number. Thanks for any insight.
Old:
New:
Old 03-01-2020, 01:16 PM
Patrick
pfarah's Avatar
After conducting a bit more research, it appears that the wrong (thinner) seal was installed along the inner axle bearing. The part number ended in "G" where the correct seal ends in "H". Another PO correction!
Old 03-01-2020, 04:11 PM
Patrick
pfarah's Avatar
Found an easy way to press in the inner bearing without removing the muffler or banging away with the ole' hammer. Harbor Freight's seal kit and some threaded rod to the rescue.
Old 03-01-2020, 04:22 PM
Patrick
pfarah's Avatar
I've used Timken Red Premium Wheel Bearing Grease for many years with great results.
Old 03-01-2020, 04:27 PM
Great stuff you're doing there Patrick.
John
Old 03-01-2020, 04:41 PM
Patrick
pfarah's Avatar
Thanks! Re-installing the parking brake hardware is being a pain. Time to stop for the night and leave it for a while...
Old 03-01-2020, 06:05 PM
