suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
Flushing the head
Hello Guys,
Is there a way to flush the head of an 86 N/A with out removing it and doing an overhaul? I'd like to pursue the least anount of hassle and would like to just give it an (enema) so to speak, does anything exist to remove the sludge from 175,000 miles of driving?
Thanks in advance,
Frank B
My car is naughty
Old 04-07-2003, 12:45 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Well, if you find a toilet big enough...
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 04-07-2003, 02:02 PM
ae1969's Avatar
Send a message via ICQ to ae1969
You could always try boiling it like an oil cooler I heard of...........
If possible dip the whole car.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 04-07-2003, 03:29 PM
Roger Hall's Avatar
No one thing will work. The best you can do is run ATF instead of oil for 20 min to clean the lubricated parts. Use radiator flush, and run two cans of injector cleaner in about 1/2 a tank of gas. Pulling the valve cover does not give you much access to clean anything.
Take the head off and shower with it. If its ok with Pam.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 04-07-2003, 03:45 PM
suck my tail pipe
Frank B's Avatar
Thanks Roger, that won't sit to well with Pam hehe...
I'll just leave it alone and have it overhauled at the 200K mark, that'd probably be the best thing to do. I don't have any noticeable engine problems (knock on wood) I was just concerned about sludge causing a problem that's all.
Won't running all of that injector cleaner fry the plugs?.. hmmm.. does it actually disolve the crusty stuff on the tips and on the piston head? any other advice would be usefull also.
thanks
Frank B
My car is naughty
Old 04-09-2003, 07:03 AM
Roger Hall's Avatar
Yes its alot of injector cleaner. I am doubtfull that injector cleaner does much to clean valves or pistons. Your car will most likely run rich but the plugs should be fine.
Roger Hall
81 924 N/A
Old 04-09-2003, 07:18 AM
suck my tail pipe
Frank B's Avatar
O.K. thanks Roger, I appreciate that
My car is naughty
Old 04-09-2003, 07:24 AM
Use a good synthetic oil, it costs more initially but you have more mileage between changes and it doesn't leave deposit's like dino does.
Old 04-09-2003, 07:34 AM
overkill's Avatar
Send a message via AIM to overkill
HA,... HA,.... HA,....
{1987}944S - (SOLD).
Old 04-09-2003, 09:01 AM
about the ATF thing... didn't AFJuvat work on an 911 that was had a big problem from that??
Old 04-09-2003, 02:44 PM
um yeah, but the guy like replaced all the oil w/ ATF. One quart ATF to 6 qts oil isn't so bad.
Old 04-09-2003, 03:24 PM
AFJuvat's Avatar
Yeah, he was running 75% ATF
1 qt out of 6 will not hurt - drain out the old oil, add oil & ATF, run at idle for 20 minutes, drain, change oil and filter.
Cooling system - flushing is about the only thing.
"Inside the engine" Techron. In a pinch, you can use Toluene in the gas tank .5 - 1 gal of Toluene and then fill the tank.
Change fuel filter, You can also change the fuel strainer.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-09-2003, 03:40 PM
Hunter S.'s Avatar
Pull little shiney handle. Flush what?? Ask a stupid question get a ..............
Old 04-09-2003, 11:29 PM
least common denominator
scottmandue's Avatar
Very true, I ran synthetic (Mobil 1) in my Korean econo car and after 100K miles it looked like new under the valve cover.
1995 Miata Sold
1984 944 Sold
A lie can travel halfway around the world while the truth is putting on its shoes.
Old 04-10-2003, 09:01 AM
suck my tail pipe
Frank B's Avatar
Hunter. What's your problem? I hope for your sake that I never see you. If you'd like to continue acting this way towards me, why don't we meet somewhere?
Or you can just apologize. Or go away.
My car is naughty
Old 04-10-2003, 11:13 AM
Z-man's Avatar
Hunter, Frank: a suggestion: go to opposite ends of the room, AND COME OUT FIGHTING!
Seriously: for whatever reason, it isn't working. So please, give each other a little room.
Hunter: your post is uncalled for. If you have a beef with Frank, take it up with him offline: email, PM's AIM, phone calls...etc. are a far better way to deal with this, than to come up with random comments like above.
Frank: no need to be threatening and such. Take a breath, and step away from the keyboard....
EVERYONE: just play nice.
Thank you,
-Z-man, moderator.
1989 944S2 - June, 2001 - January, 2014
Visit my homepage!
Old 04-10-2003, 12:04 PM
Not to step on z-man's toes, but anyone read hunter s. prior posts under the search button? nothing but neg. talk towards frank
Old 04-10-2003, 12:10 PM
Send a message via AIM to Trevor
He's jealous, or Pam venting , tell hunter to respect your seniority-1212-17posts.
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 04-10-2003, 12:34 PM
SidVicious's Avatar
Frank,
I just removed my fuel filter Friday. You talk about sludge! I've pulled a lot of fuel filters from cars before, never seen one this bad. I also noticed the fuel line that connects to it was dry-rotted badly. Very glad I did that little bit of maintenance. If you haven't done yours yet you might want to consider it. Just my $.02.
Old 04-10-2003, 01:19 PM
