-   -   A/C Leak again (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/105515-c-leak-again.html)
Scott R 04-07-2003 04:01 PM
A/C Leak again
I need to know if anyone has ever had to replace the two o-rings for the high side and low side hoses as they enter the firewall near the battery?
I am down to 8oz of R12 again this summer and my leak detector is showing that both of these are leaking. As near as I can see I need to get the main wiring harness out of the way, some vacuum lines, and possibly the engine lifting hook. Any help would be greatly apreciated as I am running out of R12.
Roger Hall 04-07-2003 06:52 PM
Sorry I have no advice, but I would be very interested to hear how it goes. I plan to do some A/C work in the future.
Good luck, please post the results.
Lawrence Coppari 04-08-2003 04:45 AM
I was able to do mine without removing anything. My car is an '86 951. I replaced the compressor front seal. However the darn thing is leaking from the rear of the case now. It only holds a charge for a couple of days.
Putting the car on a lift and removing the compressor might make attaching the lines easier. The lines are very stiff, and by removing the compressor, you can rotate it, etc.
Scott R 04-08-2003 06:04 AM
Lawrence, thanks but its the actual hard lines as they enter the firewall into the passenger compartment. But I feal your pain I have already replaced the compressor, that was last summer and the front barrier hoses.
Lawrence Coppari 04-08-2003 06:20 AM
Sorry, I did not completely read your post.
Scott R 04-08-2003 06:28 AM
Not a problem, I am searching the archives and coming up with nothing, the best part is my mechanic has never done this repair before either.
I guess I would document it and take photos, but it looks like I may be the only one that will ever need to do this.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
