1986 944 non-turbo injectors not firing
I have a 1986 944 non-turbo which pumps fuel to the fuel rail but does not fire injectors. I have replaced the injectors and tested the connections with a noid light, all came out fine. I am a bit stumped on what to check to get these injectors firing.
Good luck, George Beuselinck |
Hello there:
Be sure your battery is charged and showing at least 12.5 volts. (Simple test w/o volt meter...turn lights on, start the car. If lights go dim...battery is bad. Next, the usual suspects are as follows: DME relay DME/ECU brain Reference and Speed sensors Follow the troubleshooting process George has suggested above. Keep us in the loop, so we can help. Good luck.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
Porsche 944S Club Sport
Orca:
Check Your Harness Injector Grounds. ECU Injector outputs are "Open Collector". If your Grounds are weak or floating, you will have weak current flow and no enough to drive Injector impedance(s). This is a very bad problem on all the German cars(BMW Porsche/ VW/Audi, Mercedes Benz, Etc.). If you can run a 8 Gauge wire from the Harness ground point located near your Flywheel sensor back to your (-) battery terminal. This usually works...(15 Min. Fix) ***Suspect Floating Ground*** Keep us posted.....Later.
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
