I have a water leak coming out of or around the squirrel cage fan directly under the glove box. Happens when I wash the car or driving during the rain. Common problem and fix or something unusual? The battery tray seems to be draining fine.
1982 911SC 1987 924S Last edited by rbuswell; 05-22-2020 at 10:25 AM.. Reason: Additional comment |
944 addict
You didn't specify the type and year of car so it's hard to help you with your question.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Sorry. 1987 924S USA manual with A/C which doesn't work yet.
1982 911SC 1987 924S Last edited by rbuswell; 05-22-2020 at 11:03 AM.. Reason: More detail |
Have you taken the battery out and looked for pinholes in the underlying sheetmetal?
That is the most common source of leaks in that area of these cars. You could still have some leaks even though water is coming out of the drain too. Last edited by Spring44; 05-22-2020 at 11:48 AM.. |
Remove the battery. Have a friend shine a very bright light up at the battery tray from inside while you look from above for pinpoints of light. That will be where water is coming in. Also, where the tray is spot welded into the firewall (and covered with caulk that has notw dried out) is another source for water intrusion (that invariable ends up behind the passenger seat.)
Good luck, George Beuselinck |
As you both suggested!
1982 911SC 1987 924S |
I had a similar issue recently, and did the search in the battery tray. Apparently this is a common leak spot, at least in the 951. Anyway, nothing seen there, so I grabbed some UV indicator from a local parts place, and added this to a gallon of water, mixed it up and dumped it into the battery area. All of this at night. Then took my black light into the passenger compartment and shined it up under the dash.
In my case there was a small hole drilled in the interior, which went through the rain channel inside the fender. Anyway, if there’s nothing obvious, this is one effective way to find these tiny holes.
‘86 Porsche 951 '69 Ford F100 '83 GL650 rat bike '17 F150 Last edited by cfassett; 05-22-2020 at 06:08 PM.. |
Another good idea!
A couple follow ups:
1982 911SC 1987 924S Last edited by rbuswell; 05-23-2020 at 09:32 AM.. Reason: Formatting and another question |
https://photos.google.com/photo/AF1QipMn0cPQ5bSVwf4E4I-56a4GtDWZVxufjskmwiGP
Not sure how I missed this before but these are two holes to the right of the battery that appear to need caps on them. Although they aren't at the bottom of the tray, they do look like they could let a lot of water in. Certainly a lot more than pinholes.
Even though the A/C is still there, I can get a full view of the bottom of the battery tray. Turned out the lights in the garage (nearly darkroom dark) and asked my wife to shine a very bright flashlight all along the battery tray and into the two holes I mentioned above and there was no hint of light coming through. Zero.
