'83 Oil Pressure
After replacing the oil cooler seals, I now find that the oil pressure sending unit is leaking. So I have taken out the oil cooler again, and will replace seals again with a new ones.
On the oil pressure unit, (Bolt spring, and end unit - this is the older unit), in some of the repair discussions it says that there are O-Rings for the oil pressure unit that needs to be replaced.
Since I have the older unit that seems to work fine, are there any O-rings? Or were the references to O-Rings for the newer one-piece oil pressure unit?
Any help with would be appreciated. I donít want to do this job again.
Old 04-08-2003, 07:10 AM
