headlight troubleshooting
My driver side headlight doesnt work when I turn then on(DIM)(only the p/s headlight ). But when I turn it to bright, it works fine. Any thoughts
If I understand the problem correctly, one low beam is out but headlights work on high beam. Each bulb has two filaments. Your low beam has burned out.
Doesn't the car have seperate fuses for high / low beams on each side of the car? can't remember, and the manual is out in the car.
| All times are GMT -8. The time now is 12:27 AM. |
