What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
adhesive and wheels
I have phone dials on my car. I also have old adhesive on them from the old wheel weights that are not there anymore. Is there a commercial product out there that will easily cut through the adhesive without damaging the wheels?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 04-08-2003, 06:23 PM
andrewgoh's Avatar
I only started using this recently...3M Tar, Grease and Adhesive Remover...but never tried removing adhesive on wheels...perhaps this will work? It is a transparent liquid based remover.....almost has the consistency of liquid silicon:
http://shop.store.yahoo.com/autobodymagic/3madtarwaxre.html
http://www.autogeek.net/3mtargreasre.html
Old 04-08-2003, 06:40 PM
Roger Hall's Avatar
We use a product called Goo Gone to remove stickers at work. Its available at Home Depot. It shouldn't harm the metal, but it will ruin plastic parts. We also use mineral spirits, its a milder choice and should not cause any problems.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 04-08-2003, 07:52 PM
Blackfoot's Avatar
be careful when using solvents like goo gone, because remember that the wheel surface isn't metal, it's clear coat.
Old 04-08-2003, 08:31 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
I have the same problem with my fuchs, need a suggestion for removal. I have goo gone, but now I am scared to use it
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 04-08-2003, 09:20 PM
Blackfoot's Avatar
i'd use it, but carefully.
like carter says, always have a backup.
Old 04-08-2003, 09:31 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Goo Gone will work. ONLY!! have a hose running to rinse immediately.
I refurbish alot of industrial (painted) equipment and I use a spray bottle with water and never affected the paint surface.
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 04-09-2003, 06:55 AM
alright, i'll give it a go, let you know how it went after it stops raining here
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 04-09-2003, 03:27 PM
OK, ITS A GO..I will work on them this weekend and let you know..
3-924's (Sold)
1967-912 (Traded)
Old 04-09-2003, 04:26 PM
Also, 3M genreal adheasive remover works great (I refinish rims for customers all the time, and have used this product in this very application). Put it on, let it sit for a minute (or a few minutes depending on how bad the goo is) and wipe off. I use it all over the place and have never had it harm any finish I have ever put it on (paint, clear coat, annodizing, etc...)
I've also used goo gone to remove stubborn bugs, etc... and never damaged painted surfaces BUT I would keep some fresh water near by as it is a bit more aggressive than the 3M.
both are available at most auto parts stores.
Hope this helps,
VT944
Brian
1985.5 944
Dodge Viper Blue on black/tan
white face gauges
throttle cam
short shift kit
Old 04-09-2003, 09:56 PM
Won't gasoline work?
1994 BMW 525i dark blue
1967 Saab "96", Red, Needs Help
Old 04-10-2003, 09:37 AM
