968 Convertible top broken
Hi,
just acquired 968 convertible, but the electric top is not working. I unhook the front catches and hit the switch. the windows roll down, and I can hear the motors behind the seat running, but nothing happens. Its like a cable or such got disconnected. Anyone know how these work and what the issue might be? thanks! DK |
It is probably in manual mode, which is faster and less chance of breaking a bow. There are tow plastic pieces that pop out in the rear side panels that give you access to the motor controls. I've put mine in manual mode but have never tried to go back.
unfortuantely, as i understand it, now that you've hit the switch, you will have to find the position the cables need to be in to re-engage the motors
i did the same thing - i'm just yanking the motors instead |
Ah - I didn't know there was a manual mode..when I pop out the two round covers I see a bolt on each side which looks like it has been loosened all the way out. I guess if you tighten it right up it causes the motors to engage and do their stuff? But, as Flash says - the alignment could now be out. So has anyone ever had to do the 'alignment'? Or do I just make it 6lbs lighter and put the motors on Ebay? Manual is no big deal..
Thanks for your responses! David
1996 993 C2 1995 968 Cab 1976 Norton 850 |
lol - that is exactly what i am going to do - since you have to get out of the car to install the boot cover and a towel or something across the window anyway (and this really is important if you want to keep your top in good shape) i figured what is the point of a power top?
however, i believe the top manual has instructions as to how to realign the motors with the cables and such |
'90 S2 Cabrio-top
The motorized mechanism on my "new" S2 Cabrio runs (noisily), but as a 914 owner, getting out and opening the trunk is no big deal here. Questions are: Are there any problems in raising/ lowering the top manually--I wouldn't like to disable it if I might decide I prefer to have automatic? -Unless the re-connect is pretty foolproof, at least. Also: Does ANYONE have the "top manual" mentioned by another poster, as, among the documentation stuff I got at purchase, a specific top manual was not included. Can someone make a xerox copy and mail it? PM me--thanks.
Boxers: '72 914 1.7 w/ AA's 9014 body kit, '73 914 2.0, '87 Westfalia VW, and '90 Subaru 2-whl. dr. wagon (beater); AND the "new" '90 944 S2 Cabrio--not a boxer Q: Why do some guys like BMWs? A: Because they can spell it. -- AIM HIGH - You just might hit the moon! And if not, people will think you're a real spaceman, anyway. |
Re: '90 S2 Cabrio-top
to lower it manually,
(BEST WAY TO DO THIS) 1> lower roof completly 2> pop open the two round covers either side. 3> undo the bolts either side, DOES NOT NEED TO BE FULLY UNDONE about 2 or 3 turns 4> then lift or lower by hand 5> DO NOT now ues the botton, it might be on a fuse (remove this) WHEN YOU WANT TO REVERSE THIS 1> lower the roof 2> tighten the bolts 3> put in fues if you took it out then bingo If you do it any other way, you'll be messaing about trying to get the motor synch with the position of the roof Quote:
----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com |
TBH
I've never used a towel, though I have been told about it. Never had any problems at all with scratches, Quote:
you are lucky - i have the original top in my car, and the window looks brand new - every other top i have seen that does not use a towel or soemthing has marks and scratches on the window - i am in southern california, so the top is down at least 10 months out of the year
Has anyone heard of the 'B' Pillars snapping in the 944/968 Cabs . I have just recieved into my workshop an '89 944 Cab that has both 'B' Pillars snapped in half . The customer and his wife both say it happened with them sitting in the vehicle with the top going down under normal power , so therefore there was no 'outside assistance' . This is the second time I have come across this problem , any help would be appreciated .
TREAT IT WITH A PINCH OF SALT,
usual cause for this, is trying to force it, they dont usually jst snap Quote:
The motors are very strong on the 968 and I imagine they are the same on the 944 cab so it is possible. Usually one of the bows breaks though.
Pinetree you have PM
94 Blue/Grey 968 95 White/Chestnut 968 |
it happens, and more often than you would think
the cause is misalignment or varying tension of one of the cables - as speedbump said though, it is usually only one bow at a time given that both are broken, you are looking at a new frame |
Thanks for your help guys , I've started a thread about this problem with a couple of photos . Here it is:
Broken 944 Cariolet B pillars |
How do you remove the B Pillar without removing the entire top? I have a broken pillar too. One motor stopped working and "pop" I have put it in manual mode now... I've removed all the plastic and rear parts but cannot figure out how to get the pillar off
Mark '83 Porsche 944 NA '90 Porsche 944 S2 |
For anyone with a convertible top. The Main Bow costs around $900 each. If the motor actuated cables get out of alignment you run the risk of breaking a main bow. I would venture to say that most of us that do own convertibles have placed them in the manual mode. The link below is for cab top maintenance.
http://www.968forums.com/Miscfileupload/968CabTop.pdf Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
With the cost of replacing bows being so high, is there a possibility of having them repaired (welded or brazed)?
mixed reviews on that. a couple of guys have succeeded, at least in the short term. most of the attempts i've seen and heard of though have failed horribly, taking the top with it.
I went manual and then installed some tweeters in the holes where the plugs go
![]() It is vary quick and easy to open and close. I have seen an attempt at repairing the main bow that failed after a few days. Seems the metal used is almost impossible to repair well. Mark |
