rcoopers's Avatar
944 with auto question
i have read threads about the nasty auto flex damper.what are the mileages they are to be replaced? i've seen 30-40k and once...is just different opinions or what?
what are the chances it has been replaced already...the person who is the owner is trying to find out.....thanks for your time............................
Old 08-26-2013, 10:05 AM
I really depends on the shape of the damper.
I heard that it was around the 60K mark. I am sure the one in my car had been replaced at some point, but I have no idea when - didn't get any maintenance records with the car. When I pulled the engine it had several large cracks forming around the outside edge, I decided to go with the clutch/pressure plate setup. If you pull the starter you can get a really good look at the damper to see how many cracks it has.
Perhaps someone else will chime in, just speaking from my experience.
Old 08-26-2013, 01:26 PM
rcoopers's Avatar
thanks good idea
Old 08-26-2013, 01:33 PM
tamathumper's Avatar
It is an as-required replacement. As with all rubber and plastic, there is no mileage at which it will fail, because it depends on heat and age and oxidation as much as anything.
Old 08-26-2013, 02:48 PM
To give you some idea, mine went at 125k miles and it was about 22 years old. I think age has as much to do as miles as the rubber hardens and gets brittle with age regardless of miles.
Old 08-26-2013, 03:52 PM
rcoopers's Avatar
great stuff thanks alot....
Old 08-26-2013, 05:04 PM
Hello Ya'All,
I'm interested in doing this manual clutch swap on my automatic 1984 944. Does anybody have a complete list of parts including bolts for the flex plate?
I'd be very interested in having a detailed list of parts and the procedures.
If this is already in a thread, could someone send me a link?
Thank you very much,
Frank
Old 04-30-2020, 10:52 AM
911tracker85's Avatar
I will be tackling this in the near future. got an 87 924S auto and from the clanking noise suspecting this. when I pull the engine I'll look at replacing with a used clutch kit. all depends on what I find.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 05-02-2020, 06:24 AM
Patrick
pfarah's Avatar
It so happens that I have a used clutch kit from my 84 (manual rubber clutch) that still has meat and in good shape. It's available for free to anyone who wants it; I only ask to cover the shipping costs.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 05-02-2020, 06:39 AM
