Exhaust heat shield vibration
I've got an 85.5 and the heat shield over the catalytic converter makes vibrating noises at certain engine speeds. I played around in there and a fairly small peice of foam fell out. Is there foam insulation between the cat converter and it's heat shield to act as a vibration damper? And if so can you order that part?
Old 07-30-2000, 03:17 PM
