-   -   Reverse Light Switch (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1063286-reverse-light-switch.html)
onZedge 06-05-2020 08:34 AM
I am going to replace the failed reverse light switch on the transaxle.
I did find the torque value to be 30 lb-ft.
Neither the PET or FSM show a gasket for this switch.
Does anyone know if a gasket (aluminum, copper, or fiber) is suppose to be used on installation?
Thanks,
TheSecondChris 06-05-2020 09:02 AM
I replaced mine a few weeks ago. It's a little tricky to get a wrench on it, but not so bad. The old one is in my hand. No gasket that I found on the old one or included with the new one.
http://forums.pelicanparts.com/uploa...1591376429.JPG
pfarah 06-05-2020 09:38 AM
Whoa...!
It's 30 NM not Ft/Lbs. Be careful not to strip the threads.
http://forums.pelicanparts.com/uploa...1591378637.jpg
TheSecondChris 06-05-2020 12:30 PM
Nice catch on the torque units! Good luck getting any kind of torque wrench on that w/o removing the transaxle. Personally, I just tightened until it felt snug. I was surprised how it came out relatively easily, so must not be installed super tight to begin with.
pfarah 06-05-2020 01:37 PM
Groovy...
onZedge 06-05-2020 05:48 PM
Well, 42 Nm does in fact convert to 30.9 lb-ft (see below). I will use 22 lb-ft (makes more sense). Hmmm, wonder if there is an o-ring.
http://forums.pelicanparts.com/uploa...1591408006.jpg
pfarah 06-05-2020 06:21 PM
Interesting, especially when both NM and Ft/Lb values are the same. That looks to be a type-O.
jjeffries 06-06-2020 04:55 AM
I remember being schooled as a teenager by older guys to be cognizant of torquing hardware by feel. Of course torque wrenches and specs have their place, but blind reliance on them can create other issues.
Doing 911 valve covers nuts comes to mind.
“Feel the torque, Luke”
John
onZedge 06-08-2020 11:43 AM
For the 924S (and early 944's) with two transaxle mounts, it is easier to just support the transaxle and remove the right side mount. Makes it MUCH easier to access the reverse switch and get tools in there. I also added a size A015 o-ring upon installation and torqued to 22 lb-FT.
...and then I noticed I will need to replace both inner CV axle boots...*sigh*
