Send a message via ICQ to interglossa
URGENT HELP NEEDED.. oil leak
It seems i'm leaking oil from my #4 exhaust port, i was assuming i have a bad head gasket, but i'm worried that it's worse than that... IDEAS?
Edit: No black smoke from exhaust, just the leak
My '83 Sets me free!
Old 04-12-2003, 12:58 PM
Roger Hall's Avatar
Are you sure that its not comming from the valve cover gasket?
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 04-12-2003, 08:16 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
has the car been sitting?.. sometimes the valve cover gasket likes to shrink when not (heated up) regularly. if it's not a huge amount of oil run it for 30 days then look for the leak again, the gasket will probablly swell back to it's appropriate size and stop future leaking....
My car is naughty
Old 04-12-2003, 08:25 PM
It doesn't leak unless the car is running. I cleaned it off and took a look from the underside. After a couple seconds running the oil seems to pour from the underside of the exhaust port and stream down the manifold. No oil mess from the cam housing or the rear cam housing seal.
What i really need to know is would a bad head gasket cause the oil to leak into the exhaust port or is there some other sinister problem that causes this.
The severity will make me decide whether to fix it or part it out. I'd like to keep the car on the road, but i also have a limited budget.
Old 04-13-2003, 12:58 AM
Does anyone happen to know the part number for the valve cover gasket for a '83? I couldn't find it on Pelican Parts's site.
Thanks,
L-
EDIT: Duh! I found it!
83 944- Garage Queen
03 Mustang GT- I dont' do anything "Mild", do I?
In the land of the funny underwear!!!
Old 04-13-2003, 10:15 PM
