Question about Fan Control Relay G10
Does anyone have any knowledge of the Fan Control Relay (G10) causing electric issues with the A/C not working? I've traced all the other possibilities and am wondering if any failures in the G10 relay might cause inability of power getting to the A/C relay?
The compressor clutch works and the circuitry from the relay connections are good also. I've also replaced the A/C relay with new, HVAC controller head. installed an in-line fuse in the compressor power line and the fans work as designed. The pressure system is also fully charged. I know I could install a separate switch to power the clutch directly but I can't bring myself to do that yet.:confused: |
| All times are GMT -8. The time now is 06:29 AM. |
