curtisr
curtisr's Avatar
924s AC Delete Belt Size
Sorry everyone but my searching has left me more puzzled than before...
I have an '87 924s and plan to delete the AC and, of course, move the alternator to the bottom.
When I search for the correct belt size there are lots of listing for AC delete but it assumes that your car did not have AC to begin with. Is this the same thing? Regardless, my question is what size of belt do I need to make this happen?
Thanks in advance.
Roger
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 02-21-2017, 11:43 AM
ac delete belt is the same as if your car never had it in the first place.
for your 924S the "interchange part number" for a belt to get at your local parts store should be 6K720
Old 02-21-2017, 11:49 AM
curtisr
curtisr's Avatar
Got it and thank you, v2!
Old 02-21-2017, 11:56 AM
rbuswell's Avatar
Porsche Crest Ancient thread but someone may know
Thanks in advance.
Roger
I need to run the car without the A/C compressor for a while and would like to use the aforementioned belt (which I've bought) on the alternator. I can't really tell how to configure it to work. Moving the alternator down makes sense but dumb ol' me can't see how it's done. The brace for the compressor applies the tension but what applies the tension if the compressor is gone? Thanks for the help.
1982 911SC
1987 924S
Old 06-12-2020, 03:16 PM
9FF 9FF is offline
9FF's Avatar
To do it “factory” you need to buy an AC delete bracket which replaces the bracket that’s on there which currently supports both the AC compressor and the alternator. You can buy the AC delete bracket from Porsche or a number of aftermarket vendors make a substitute. I recall the 944 Cup racers had a workaround to buying the bracket, maybe one of them will chirp in and advise you, otherwise this may help:
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 06-12-2020, 05:05 PM
PN for belt and procedure in this thread.
no tensioner required, just ease the belt on like an old V belt...
https://rennlist.com/forums/924-931-944-951-968-forum/420972-bargain-early-ac-delete.html#post5395126
Old 06-12-2020, 06:03 PM
rbuswell's Avatar
Porsche Crest Wow, lots to consider
Thank you guys. I'm only taking the compressor off line until I can rebuild it for R134A and get the hoses rebuilt. The hoses that go into the cabin are a real bear and I haven't found an actual tutorial for that yet. It looks like you dismantle everything inside of the cabin so that you can twist and turn the steel pipes in the right direction to pull through the firewall. A really big deal. Porsche proved, yet again, that they really don't want to sell us anything other than race cars for the street. The car is black and I live where it gets pretty hot so A/C delete isn't an option for my new daily driver.
If I'm understanding V2's post, the belt will hold tension after sliding it over the pulleys. I suspect it holds long enough to get this project done.
BTW, 9FF, I've contemplated building a 924S race car someday so sharing the Excellence article is a big plus. I don't think my Excellence collection goes back that far.
1982 911SC
1987 924S
Old 06-13-2020, 03:29 AM
911tracker85's Avatar
I have a LR AC delete bracket I removed from my 86 951 now that I am rebuilding the AC.
with the engine out for full rebuild, decided to fix the AC. got to looking and realized I needed to remove the brake booster to get my hard lines out for rebuild. they were the original cause of AC not working and having me install the delete bracket.
I thought removing my AC lines were a pain until I happened to look at the lines in my friend's 84 944 we are working on and saw they did not disconnect at the firewall.....
got my lines rebuilt and back in the car. now finish up reinstalling the MC and booster and then putting the engine back in.
good luck.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 06-13-2020, 06:34 AM
rbuswell's Avatar
Porsche Crest
good luck.
Mine is a '87 924S. The hoses/lines that go into the cabin on my car are steel (or whatever the hard metal they are made of) and have some bends. Since they are hard, they would need to be twisted and turned to make it through the firewall. That's why I think I have to take out all the A/C and heater gear under the dash to provide relief for them to twist. There are two brackets that hold them to the firewall which don't appear to be the hangup but I may be wrong on that since I haven't tried to extract them from the cabin yet. My lines seem to go in a more diagonal direction than yours to a bracket about 1/2 of the way down the left fender. It doesn't look the the MC or power booster would get in the way. I'd post pictures but I have yet to figure out how to do that on Pelican so I gave up trying years ago.
I'm not an expert on A/C but one thing I've wondered is whether I could abandon the steel throughout and have new barrier hoses made of rubber all the way. Then I could just cut all the old stuff as needed and us pliable hoses going back in.
1982 911SC
1987 924S
Old 06-13-2020, 07:39 AM
rbuswell's Avatar
Porsche Crest Any way to be sure of belt size?
The idea looks like it will work fine but I compared the picture in the thread to my configuration and they look different. Is there a way to measure my actual belt length accurately?
Also, doing it this way doesn't put too much pressure on the alternator bearings, does it?
1982 911SC
1987 924S
Old 06-13-2020, 08:54 AM
wrap a string around the alt/crank pulleys and find the closest belt to that length?
Old 06-13-2020, 10:42 AM
rbuswell's Avatar
Porsche Crest Good thing I asked ...
Took my wife's measuring tape for sewing. Put it around the center (at the grooves) of the two pulleys and it came back 33.25 inches which is 844.55 mm. I assume that is a 845 mm belt. Uncle Maz was saying 855 mm on Rennlist so it is a little different. That came back as a 6PK845 belt. Sound about right?
Also, any concerns about the alternator bearings?
Update: Did some additional research and the part number represents the outer circumference of the belt. To get to the inner circumference of 845 mm, the 6PK850 appears to be the correct size given the thickness of the belt.
1982 911SC
1987 924S
Last edited by rbuswell; 06-14-2020 at 04:54 AM.. Reason: typo in title and wrong part description
Old 06-13-2020, 01:38 PM
rbuswell's Avatar
Porsche Crest Final report for my car
The 6PK850 was also too big. Given how much slack there was I thought the 6PK845 would be too big too. As it turns out the 6PK845 is mostly used for a snowmobile and a couple other specialty uses so it was pretty pricey. Going to the 6PK840 meant an inexpensive Bando on Amazon. It turned out to be the perfect fit ... for my 924S engine anyway. It had a nearly perfect amount of deflection (until it gets stretched a little over time, I assume). I'm sure it will work just fine until I get all my A/C problems sorted out.
When I installed it, I put the entire belt on the alternator pulley and worked the main pulley while turning the crank. The main pulley went on pretty well but then the alternator pulley started to work itself back off. I decided to just keep turning it and firmly work the alternator end back on. Nothing is a sure thing but it looked like it wanted to stay on both pulleys even when revving the engine to a pretty good RPM.
1982 911SC
1987 924S
Old 06-27-2020, 10:33 AM
i dont get on Pelican much but I wouldn't worry too much about the alternator bearings.
they're pretty beefy for the job they have to do.
i think if the belt put up more of a fight and really needed to be forced on then that might be an issue of overtension but it sounds like you didn't have too much trouble once you saw what was going on.
Old 06-27-2020, 11:32 AM
rbuswell's Avatar
Porsche Crest Correct on both counts
I don't really know enough about the differences in the alternator mounting points for 924 and 944 cars to say the 6PK840 will be the right belt for everyone. Through trial and error I found it to be the right one for my car. Once I got the belt pulley on the alternator end to cooperate, the belt seemed perfect for the job.
I don't think the belt is stressing the bearings. I had the alternator rebuilt by a reputable firm and I'm confident the bearings were inspected and replaced with good parts if needed. The only other thing I would suggest is to keep a close eye on the belt since it should stretch over time. Replacing a $12 belt from time to time is a small price to pay for those who want to do an A/C delete. Thanks again for your insights.
1982 911SC
1987 924S
Old 06-28-2020, 03:44 AM
