Sunroof Issue
Hey guys,
Ok, Iíve discovered something peculiar.....87 944 turbo..firstly, we know the way the sunroof is supposed to work - the retracting and engaging of the sunroof lifts(so you can remove the roof) can only be done in the ignition accessory 1 position, and that is the only function that switch does when the car is off and in accessory 1.....you then turn the key to accessory 2 position(or ON), and the sunroof switch will then only raise or lower the roof....SO...whatís happening on my car is...with the ignition switch is position 1, the sunroof lifts retract and return to lock perfectly as they should....turn the ignition to accessory 2(on) and the sunroof switch still only retracts/re-locks the lifts.....the sunroof does not go into up/down operation mode.....anyone ever have this happen? Thanks in advance for your assistance.
86 Carrera / 74 Euro Carrera Tribute - Grand Prix White
87 944 Turbo hot rod - Alpine White
09 Cayenne Turbo S - 610hp beast
Old 06-14-2020, 02:59 AM
