1986 944 na
Hello 944 guys,
I’m going to replace my door window rubber channel that glass rides in. Does anybody know if it is glued in place or just compression fit? If glued what type is best to use? Any tricks that you might have would be appreciated! Thanks, Mike |
944 addict
Compression fit. I used a 1/4 inch socket extension and slid it the length of the channel to seat it. Start at the upper outside corner and go towards the front and then do the rear vertical channel. The extension fits nicely in the channel. Be careful not to just push it in because it will puncture the channel.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
