andrew4266's Avatar
944 Injectors
I have an 87 944S. The engine turns over but will not start. I have spark at the plugs but none at the injectors. I did have a little at the injectors until I thought the alarm was the problem and unplugged it. Now the alarm will not work with it plugged back in and still no spark at the injectors. I did notice that I could smell a quite of bit of fuel under the hood even thogh there is no leak. Would a bad DME cause this or the alarm?
Old 08-09-2000, 03:48 PM
andrew4266's Avatar
This all started when I had the car towed and the starter replaced. Before that the car ran fine. And I have replaced the DME relay.
Old 08-09-2000, 04:02 PM
One assumes you checked all the fuses...
Old 08-09-2000, 04:14 PM
andrew4266's Avatar
all the fuses have been checked
Old 08-09-2000, 05:29 PM
tri tri is offline
Check the fuel pressure. It may be a problem with the regulator if you smell fuel under the hood.
Old 08-10-2000, 06:00 AM
