85 1/2 944 relay part numbers?
i have a 1985 1/2 944 project car that is now running. the previous owner robbed the relays. i am missing g8 warning buzer. g16 gong/catalyic convert warning and g9 wiper intermittent does anyone have a listing of part numbers for these? thanks
ps these relay are located in engine compartment on the drivers side of the car in a black plastic case |
Is the 85 1/5 relays in the engine bay like the 86? If so I can help you.
yes, they are in the engine compartment.
Ok, I'll check now. brb
Ok, I'm missing G8 but on the cover it says (warning buzer) but I hear the warning buzer coming from G16.
G16 is 928.618.102.03 G9 is 928.615.101.01 |
thanks i do have the ...102.03 and i put it in its proper home. i think most people take out the warning buzer anyway. it is the set-belt warning. thanks
gong cat buzzer is retarded.. it's really annoying.. take it out and back over it several times to ensure it's been modified properly, then apply appropriate amount of gasoline and ignite.. then your mod will be complete....
Frank B |
Still on the subject of relays.... the DME relay.
Does anyone have problems using the new (993.xxx.xxx) relay on their 86 944 ? I bought a spare relay the other day and was told the new DME relay (993.xxx.xxx) replaces the old 944.xxx.xxx relay. It works BUT it is taller and I cannot close the fuse box cover - extremely bad since the fuse box is in the engine box and if water gets in ..... So do I have the wrong part or do I need to change the fuse box cover as well ??? Any one experienced this ? shlim 86 944 |
Just because you can't close the cover I woudn't use the new type. Water will short everything in that fuse box. Cover or spend $$$ |
| All times are GMT -8. The time now is 01:12 PM. |
