does my 968 have the sports suspension set up?
I was wondering how i tell if my 968 has the mo40 or whatever it is called suspension set up, as i think it may have had specified.... any way i can check it?
Old 04-22-2003, 02:15 PM
Scott R's Avatar
Under your hood, and on top of the strut mounts you may have a plastic cover that covers an "adjuster" for the strut, thats the damper adjuster for the front Koni's. These are the sport struts, they would be coilover's and you would then potentially have the sport suspension.
In the rear look under the car at the shocks, if they are yellow they are adjustable Koni's, and again you *could* have the sport suspension package.
The best way to be absolutley sure is to look under the carpet in the rear above the spare tire compartment for the "option" list if it's still atatched and check for the option code.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-22-2003, 02:38 PM
andrewgoh's Avatar
Here is an option code decoder if you need to use one:
http://www.kindel.com/Porsche/options.asp
Old 04-22-2003, 03:28 PM
Z-man's Avatar
While M030 is the full sport suspension package (Limited Slip...etc), you may not have M030, but if you have option 474, then you have the sport shock absorbers (Koni Yellows)
-Z.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 04-22-2003, 04:28 PM
