engine seized I think
Tried cranking car today until it seized and I was just wondering how? how could one crank over a car until it seizes??? I replaced the starter because I thought the starter was broken and still would not crank with new starter pulled the starter tried to spin the flywheel still would not turn??? Put a wrench on the front of the motor it still would not turn over??? So how could something seize up the motor just by cranking it??? If you need more information just let me know...
Remove the starter and try and crank it over by hand (wrench on the front).
What car is it? What’s the oil look like? Any metal flakes in the oil? What trans is in it? Could be a locked up trans, I’d try to separate the engine and the trans and see if the engine is still locked.
Sorry for your troubles and good luck. Hopefully it’s something not so bad. Tony |
This was a rebuild as I recall so it may not have been prepped right, it could gall or break a ring if so.
With the cam cover off you should be able to tell if the top or bottom end is seized. With no oil the cam(s) often seizes to the raw aluminum cam journals (no bearings). |
You're in Florida so I wonder about vapor lock. I'm no expert on the subject but hoping this is helpful.
Vapor lock is caused by heat. Excessive heat from the engine, exhaust system, and/or outside temperature can cause the fuel to vaporize in the lines. Some winter fuel blends and high altitude can lower the boiling point of the fuel. This can also contribute to vapor lock |
Not trying to be flippant, but did the battery just run down while you were cranking? And make sure it is in neutral and/or the clutch is in. I agree with George, put a wrench on the front and turn. While you're at it, take out the plugs to make it easier.
Thanks you all ya'll have been great just as expected! I really don't know, one day I was driving the car literally the next day I wasn't. ****s weird???
If one of the flywheel bolts backed out it will prevent the engine from turning The fact that your oil looks good makes it hard for me to believe it’s in the engine but I could be wrong. Pull the valve cover off and look for any visible damage, pull the spark plugs and try to rock the engine back and forth from the balancer bolt with a long cheater bar.
If none of the suggestions on here help unfortunately I think the engine has to come out. How long ago was it rebuilt if at all? Good luck. It does seem like an odd situation. Tony |
PHillary,
Dumb question: Did you take a look at your timing belt to make sure it didn't snap, causing the lovely piston/valve intercourse which would prevent rotational movement? |
It is weird but when I find out I will be sure to let you all know that's for sure...Do you know it's only 134 documented S models left on the planet...So I'm definitely keep it for sure!!! Might buy a roller for an LS swap and just baby this one to death Lol! |
Man that sucks. I hope they do something to help you out.
Good luck Tony |
I have heard that they imported more than 8000 to the USA, so that number sounds pretty low. |
http://forums.pelicanparts.com/uploa...1597148521.jpg |
