-   -   Current starter options for 944/85.1 (early) starter models (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1072067-current-starter-options-944-85-1-early-starter-models.html)
944if 09-02-2020 09:10 PM
TLDR: I'd like to replace my starter. Does anyone still stock the large diameter starters?
After getting weaker and weaker and giving me a few push starts, the starter on my 1985.1 944NA has now finally given out. It is a large diameter Bosch starter with the markings 047 911 023A.
From what I've read, there have historically between two starter options that fit, an earlier large diameter starter and a later model smaller diameter starter. The later model smaller diameter starters will fit (95160410100), but its increased EMI may cause issues with speed/reference sensors and the replacement bracket to fix this is $125+. In 2012, people were enjoying a third option in Ideola starters, which seems to have gone out of business.
However, the current part number seems to return small diameter starters EG, https://www.*******.com/Porsche-parts/944/?year=1985&m=20&e=803&t=6&b=9&d=&v=12&keywords=sta rter
https://www.***************/pn/SR10X?
If I want to use the newer smaller diameter starter, the updated sender sleeve is $35 (https://parts.porschelivermore.com/oem-parts/porsche-sender-sleeve-94410132000) and it also needs a new bracket that is more expensive.
Does anyone still stock the larger diameter starters at an affordable price?http://forums.pelicanparts.com/uploa...1599109717.jpg
djnolan 09-04-2020 02:43 AM
Did you look for a local rebuilder, maybe it just needs brushes and bearings?
Jfrahm 09-04-2020 03:22 AM
How hard is it to swap the brush wiring on a VW Jetta starter so it spins the other way?
v2rocket_aka944 09-04-2020 06:10 AM
You should be able to source the retrofit sensor bracket for cheap, to use the newer skinny-body starter,
I've had a ton of them over the years and don't think I sold them any more than $20 or so.
michaelmount123 09-10-2020 05:38 AM
I have a NOS Bosch large diameter starter. It's new, not rebuilt; been on the shelf for many years. Yours for $100. michaelmount123 at geemail.
mazdaverx7 09-12-2020 04:47 AM
For comparison, I've had a smaller diameter starter on my 85.2 forb6 years and have had no issues of any kind with it. Its an aftermarket reman parts store unit.
