Newbie
Engine wobble at idle
Had a pretty significant engine shake at idle rpm and so was inspired to replace plugs, caps, rotor, and cap.
When I got the leads off the cap, one of the towers was all blowed up with material mising. Figured it was not producing an efficient delivery of electrons as it's designed and so not firing on all 4 cylinders efficiently.
Post work it's much smoother but not great. Probably have an intake leak or manifold issue..looks rough
Old 09-13-2020, 09:49 AM
An intake leak is pretty easy to check with a smoke test. Will also check the intake manifold and manifold gaskets.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 09-13-2020, 11:26 AM
dme dme is offline
Does it smooth out at a 1300 to 1500 RPM? If so, how old are the motor mounts?
dan
86 951 (sold), 86 951 (sold...PITA) 86 951 (current)
90 5 Speed Plymouth Turbo Voyager
11 Acura RDX Turbo (wife's)
Old 09-14-2020, 04:08 PM
Newbie
yeah, smooths out great once you start rolling, this shake is just at idle.
85 Mercedes 300cd sold
98 323is sold
02 325i sold
86 944
Old 10-24-2020, 05:58 PM
dme dme is offline
sounds like motor mounts to me. Very common.
dan
Old 10-24-2020, 06:39 PM
